LadyDivinitie
- May 21, 2007
- Buckeye, AZ
- 1995 Eddie Bauer
Hi Guys!!
First off I would like to thank you all for the wealth of knowledge you share with us when we need it .
Okay, here's my problem. I have a 1995 Explorer, AT, Eddie Bauer, 4x4, 4.0L, 6 cylinder nightmare (Honestly, we've started calling her the "Black Pearl). She started with a rough idle that went away when you stepped on the gas. Then the stumble got progressively worse over a few weeks. I had my hubby pull the plugs and check them and they were gapped wrong. So we bought a gap tool that had the right size and gapped them. The next day she had a really hard start and was chugging really bad and smelling strongly of exhaust around the hood area. Plug wires are brand new, spark plugs okay, cleaned IAC and throttle body and checked fuel filter, fuel relay checks out, fuel pump is whining on start up.
We did grounded the test lead to get the engine light to blink error codes and we got a 111 KOEO and 543 CM. So we thought we were on the right track to finding the problem since it seemed to be in the fuel system.
Last night after cleaning some of the things listed we put her back together and the idle was no better and no worse. I gunned her a bit to see what higher RPM would do for the stumbling and chugging. That's when we realized she is billowing blue gray smoke from the exhaust.
What could cause this? Hubby is thinking valves, but we are novice mechanics here....so what do you think? Is it time for an old preist and a young priest? Or is this fixable?
