The BIG problem with spacers is that people cheap out and buy lug-centric spacers, instead of hub-centric spacers, it gets the job done, but after all the stress on the wheel studs, the snap, then you are in for a not so enjoyable ride. Other then not using the right ones, the only other problem was stated above, which is putting a greater strain on the hubs, and bearing assemblys.
