Safing Sensor help Code 21 | Ford Explorer Forums
mdspoula
My Air Bag light is blinking a code 21 which I understand means the the safing sensor is not mounted properly. Where is the safing sensor so I can insure that it is mounted properly?
Thanks,
In the "past", there was a post related to a problem with the "safing sensor / monitor"... its on the passenger side... can't remember engine side of the firewall or the under the dash.... check the plug / grounding. BUT you might want to take precautions by disconnecting the battery JUST IN CASE, you set off the air bag system in some strange way since the two are "related a bit".
