kernowman
- April 14, 2008
- Penzance Cornwall
- '97 UK SPEC SOHC - LPG
I have some mechanical knowledge so would you say this is somehting i could do myself maybe?
No problems - quite a simple job. You will find a lot of info in this and other threads on the forum. I assume it hasn't been done by a previous owner - have a look in from the front under the upper inlet manifold - on the corner of the right hand cylinder head when viewed from the front of the car you can see the large hexagonal nut which is the top of the tensioner - if it is flat it is the old type. The new type has a cylindrical bit on it.
When I did mine I disconnected the battery first then any necessary electrical and vacuum connections. I then took of the throttle body leaving the cables connected and moved it to one side. There are eight Torx screws holding on the upper inlet manifold which then can be pulled off, again disconnecting anything that stops it being removed. The chain tensioner can be removed using a 27mm socket and replaced with the new one. Next to the tensioner is a oilway plug which can be removed with a T30 Torx. Use a long extension to get in straight to this and make sure the Torx driver fits nicely in the head of the plug, as this can fill up with dirt. The thread is slightly tapered so can be a bit tight - hence the need for making sure you are firmly in the head of the plug. Then just drop in the restrictor pencil. As they say in the best of manuals, assembly is the reverse of what you have just done - however, don't skimp by putting the old inlet manifold gaskets back as you will probably end up with all sorts of problems. Also, take care when putting in the new ones, making sure they remain properly in place and do not get snagged up.
Honest, all this sounds far worse and more difficult than it actually is.
I also replaced the rear one - that only takes ten minutes or so. My front took and hour and a half, but then I had to remove all my LPG injectors etc. first.
