Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
A chassis dyno measures torque by having the vehicles' wheels sit on a drum of a known weight and turn it. A computer measures the speed of the drum's turning and calculate's torque based on that. It gets RPM through either the ECU or the ignition system.
The RPM measuring part is easy since you do it in the same way with the scanguage as you do on a dyno (presumably).
It's the torque measurement that's in question. I have no idea yet how scanguage measures it. A chassis dyno measures it at the wheels. Scanguage measures it....somewhere in the transmission maybe?? How much torque you measure is going to affect how much HP is calculated. So if you measure more torque, right or wrong, it's going to show a higher HP number.
HP = Torque x RPM / 5252
You know one way you could really see if this is right is get your vehicle weighed with you in it. Then do a 1/4 mile run. Get the HP number that was logged on the scanguage.
Then use one of the online HP calculators you can find that estimates HP based on vehicle weight and 1/4 mile ET or vehicle weight and 1/4 mile MPH. I believe that both methods estimate flywheel HP, which is what the scanguage is doing (we think). So that should give you an idea of how much you can rely on the HP number the scanguage gives you.
