IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
I kind of understand how the EVAP works - fuel vapors collect in the canister and the purge valve (controlled by the ECU), vents these gases into the intake.
With a purge valve thats normally in the closed position, I assume the valve opens when you first crank the engine, is that correct? Also, it must open again repeatedly at some point in order to replace the volume of gasoline (that was used up by the engine) with air -- when does this happen? Is it just a timed thing like every 5 minutes the valve opens?
