Opera House
- August 19, 2002
- Cincinnati, OH
- 2014 Explorer 3.5L base
Mercon V is a significantly better fluid since it is semi synthetic and it has an improved friction modifier to reduce shudder problems found in some transmissions. It would not cause the problems you have. Chances are you would have had the same problem with Mwecon V. Never seen a Dexron III that wasn't also Mercon. Additives and flushing will not solve this.
