usapadyra
- November 23, 2022
- South Lake Tahoe, CA
- 98 Ex XLT 4.0 SOHC 2WD
Hey,
Can anyone weigh in on how much truth there is to the idea that if you have previously neglected to service a transmission, and then get it serviced, a second service should be performed a few weeks or months after?
Reading around online, there are certainly people here and there vouching for it, but it doesn't seem to be all that common a recommended practise.
The justification for the second service is that the fresh fluid, with its detergent effect, could potentially cause the filter to clog up with old buildup as it comes free and circulates. I understand the thinking, but I don't know if it's just one of those things that doesn't actually happen.
As I understand it, since the trans is sealed, the only 'particulate' material that can gather is metal shavings from the internals which should be caught by the magnet. Surely the varnish deposits etc just end up diluted / suspended in the new fluid since they aren't 'solid'?
The service history and function of the trans in my truck is as follows (1998 Exp V6 SOHC 2WD - 5R55E - I believe):
- Bought at 150000 miles
- Last transmission service on Carfax at 94000
- Around 189000 started getting slow shifting / flaring during 1-2 shift but only under low throttle conditions. Normal or heavy throttle still shifted fine.
- 190000 had transmission serviced. Got one slow shift after service, but that was it. Since then zero issues.
- Next 1000 miles, every 200 miles or so, I sucked up to 2 quarts out through the dipstick and replaced with fresh to gradually improve the condition of the fluid.
The transmission is the one thing I don't mind spending chunks on if there is worthwhile preventative maintenance I can do to keep it alive...now that I have money...I didn't really have any from 150000 miles through 180000
There's an independent transmission shop in town that has great reviews. Probably looking at $250 for the service (I don't have the means to lift the car). I guess my question is - is this is a worthwhile investment or a total waste of money?
Cheers
Cheers
