- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
allright, first off you will never get an E fan to cool an off road explorer with a OHV 4.0L in it, it just desnt work well enough with the stock radiator, it may run fine on the street, but hit the trail and it will heat up.
When you get a new clutch count he number of blades on your nylon fan, if there are 11 you are good to go. The fan should not have any cracks in it, if it does a new fan from Ford is like $35
Thermostat, you dont need to flush the fluid now since you did it recently, you will lose a little bit when you pop the thermostat housing, you will want to get a new thermostat, stock is 195, I like 180 personally but in a properly working cooling system 195 works fine. The spring goes towards the engine and the weep hole goes pointing up.
A new radiator cap is never a bad idea.
You need to burp the system properly to ensure you release all the air when you replace the thermostat.
