wheels
- October 23, 2016
- nova scotia
- 2005 aviater
i have a strange elec short my power mirror switch makes my power door locks lock and unlock wen you move it and if you use the power door lock switch to lock the doors it will blow the fuse fore my dash clock you can use the key fobe to lock doors and un lock and it is fine and you can use the out side key pad that works fine and sum times the doors will lock on there own and if it does it will pop the fuse and to day wen i try it wen i lock the door the drivers rear window
went down is there a body module some ware that control the memory seats and mirrors
