2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Ready for step test
I finished the throttle cable installation today so now I have a functional accelerator pedal.
Since the instrument cluster is now installed I have a functional tachometer and engine temperature gauge. That's all I need to perform the engine static load step test datalog. Warm up engine, start datalog at idle, hold each of the following engine speeds for 10 seconds: 1500, 2000, 2500, 3000, 3500, idle, stop datalog.
With the cluster reinstalled my alternator is working to charge the battery but my air fuel ratio meter still may have a problem. It counts down for 20 seconds after the engine starts like it should for the wideband O2 sensor heater but the AFR still exceeds 16:1 when the timer expires. I don't need the AFR for this test because James just uses the short term fuel trims. Pretty soon though I'll need to record AFR.
The airbag light flashes now for the first time since I've owned the vehicle but I no longer have the five by five warning chimes. There was no bulb installed in the airbag warning location. I think the code was 3-6 or 6-3. I'm not going to worry about it until the driver seat is in position and the side airbag simulator (calibrated resistor) is connected.
The engine seems to run strong up to 4,000 rpm (the highest I tried). It seems a little less responsive for revving. Possibly because of the increased rotating mass of the blower. However, how quickly an engine revs under no load is meaningless anyway. What's important is how fast it accelerates under load.
