SOHC w/ rough shifts, surging engine, runs hot | Ford Explorer Forums - Serious Explorations
cmmb1987
Marietta, GA
00 xlt
alright as of now i have two error codes and im sure i should have plenty more
P1131-Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1151-Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
my 2000 auto sohc explorer has a nasty 2-3 shift and the temperature gauge was a centimeter from the red line
also when i am coasting at around 2k rpm my engine surges almost like somebody is tapping the brake then tapping the gas
and when im braking the rpm will shoot up 500 rpm for no apparent reason and it usually does it twice b4 im completely stopped
my rpm is normally around 6-700 and its now running at 1100-1200, please help... i think im just going to have to bring it ford again and rack up another big bill
well the transmission will shift differently and the car will idle higher when it is running hot. i would fix the overheating prolblem then go from there.
i would start with the thermostat
hmm well then hopefully it will just be the thermostat... im getting it checked tomorrow and ill let ya know, ne other things yall could come up with?
it ended up being the thermostat and since the engine couldnt handle the over heating the cpu decided to mess with everything else
you were right on man! thanx a ton
