another update..
After a night of putting the axle housing back together (we got burns, we got blisters, we got cuts), I got to finally get to fit the axle on the truck!
Ya hoo!
Check these out:
http://dweeb.lbl.gov/~tdavis/pics/solid/jun-16/solid-134.jpg
http://dweeb.lbl.gov/~tdavis/pics/solid/jun-16/solid-135.jpg
http://dweeb.lbl.gov/~tdavis/pics/solid/jun-16/solid-136.jpg
[ note - I purposely did not inline these images - they are huge! ]
Ok, the front end is supported by the red jacks under the axle. The front, yellow/white jacks are there for safety - and no vehicle weight is on them when I took those pics.
Only problem I'm having - the coils are kinda bent forward.. I'm not 100% sure it's right. I think part of it is my simple coil spacers adapters. You remove the stud from the TTB's, and get some 2"x4"x3/8" square tubing. cut, drill, bolt the stud in. It's flat, and I think that's the problem. But you know what? For what it cost.. I'm happy!
But, I like the axle position. The front driveshaft hits it dead on and is almost straight to the transfer case, there's alot of clearance, there's plenty of flex (I was jacking it up by the axle, and it took almost a foot of jacking to get it off the front frame jacks!)
We had fun - no trackbar, so you could push the truck side to side.
Only problem(s) left:
cutting trackbar, draglink, tie rods down to size. (tie rod - just cut 6-3/8" off.. the other two.. uhm.. got to measure three times, cut once..)
Then I start putting it all back together. Getting there - slowly, but surely!
Oh, and oknut - as for cutting down the axle - your correct, wider is better, BUT, some of the trails around here don't allow fullsize width vehicles on them. Also, I wasn't interested in replacing my rear axle with a full-size axle too. If was going to do that, I'd not cut them down.
Besides, cutting down an d44 axle housing is an experience you'll never forget. The damn axle tubes on 78/79 d44 are .030" larger than the holes they come out of! You really, really got to get the housing cherry red to get the tubes out and back in.
