or at least I couldn't find the answers anywhere.
What are the spacings on the c-bushing mounts for the full size 44s? I am researching putting a coil spring FS 44 under a 97 Ranger and cutting the passenger side tube down to EB axle length. If I cut the tube between the c-bushing mount and the diff down by aprox. 6" will the c-bushing mounts be spaced correctly? Or does the drivers side bushing mount need to be moved as well to center the axle and provide the correct spacing for the stock Ranger coil buckets?
