Pheonixx77
- December 14, 2002
- NY
- 02 sport trac
The U- Joints i am referring to are the ones at the END of the axle behind the spindle. THEY DO turn when the wheels turn because they are attached to the wheel, they may not be turning by the differental due to 4wd not being engauged but they will move with the wheel. try it... you will see the U-Joint binding if there is a problem. my issue is probibaly more severe than yours but like i said if your steering wanders or sticks this may be the issue. the axle shafts are not being spun by the diff, yes but they still spin freeley. otherwise something would break...look at the area behind the spindle you will see the U- Joint and if the vehicle is off the ground turn the tire IT WILL SPIN steering the truck will also make them spin...
