frost5532
- June 5, 2005
- Monroe, CT
- '97 XLT Explorer
I have a '97 XLT explorer and im putting in 2 subs i took out of my last car, they were installed by the place i bought them from but i thought this time around i would do it myself but i have 2 problems.
The first one is how do i get the cable that goes from my amp to my battery from inside to under the hood to the battery, to test how everythings doing ive just been running it on the outside of my explorer.
My second problem is the one im having the most trouble with. For a while the front left speaker would be a little bit lower in volume than the rest of the speakers, and after installing the subs (which are workin good) its starting to distort at higher volumes. Ive heard this is a problem with an aftermarket headunit amplifying the sound, then being double amplified by the external amp but im using the stock head unit and splicing rca cables in to run to the subs amp. I have an extra 4 channel amp and im thinking of just hooking that up and seeing if the problem was just in the stock amp but i cant find where the stock one is. So does anyone think the problem is in the amp, and if it is, where is it located.
