speaker wiring diagram | Ford Explorer Forums - Serious Explorations
Amc_FtoSF
Does anyone have a speaker wiring diagram for a 94? I am replacing the stock with a pioneer head unit, and the wiring harness for fords 86 and up is not correct for the speakers. When I pulled the connector off, the wires don't seem to be continuos to the speakers, because they change color.
You may want to call Crutchfield (800-955-3000). They make harness adapters for practically every vehicle on the road today. May save you some time and headaches.
Dead Link Removed
http://www.3drant.com/about/jay/Mountaineer/
Dead Link Removed
Maybe there is a specific wiring harness that's a little more updated than the one you're using. The colors shouldn't matter too much though, as the harness is supposed to clip right in with the correct matches regardless of color. All that should be happening is that you follow the directions on the back of the harness's bag, and match them to the new wires of the new head unit. The colors won't necessarily match. There are basic colors that most head unit manufacturers follow, but just a rule of thumb, as the industry has no official coloring standard. Hope that helps you a bit!
