358R
- September 2, 2012
- Clemson/Aiken, SC
- 99 Mounty 5.0
If anyone is interested, I volunteered myself as a guinea pig and pieced together a DIY intake from the Spectre parts you can buy at the auto parts stores. I can post up the part numbers that I used and pictures (once I figure that out). It doesn't look bad at all. I did have to do some modifying of parts but that's because impatient and didn't want to wait on ordering parts. There are, however, correct parts (from best I can tell) that should not need to be modified and should bolt right up, more or less. There was also a coupler that needed some convincing (also I believe could be rectified with a better fitting/more correct parts). Otherwise, not to bad.
