GVeness
- November 28, 2009
- 92 Range Rover
I am in the process of repowering a 92 Range Rover with a 4.0l SHOC V6 from a 2000 Explorer. I have used most of the Ford running gear and wiring from a wrecked 2 door. The project is just about done, however I am having problems with the speedo. I have used the explorer gauge cluster, and wiring along with the rear mounted VSS. As well I have used the Ford ABS system.
My current problem is that the speedo will not work. I have checked continuinty of the VSS circut from the sensor to the ABS module and to the speedo and it is all good. The ABS light is on. Can anyone tell me what the AC voltage output from the VSS is? and what is the voltage one can expect at the speedo head?
To add anthor twist, I have used a Dana front end from a Jeep Grand Cherokee for the front axle as I did not want to try and engineer the Explorer IFS into the old Rangy. The ABS is picking up signals from the Jeep ABS sensors in the front. Could an incompatibilty between the Jeep speed sensors and the ford ABS unit be a problem?
I'm not real concerned about ABS, but the speedo and related info needs to be there. As yet I have not driven it, only ran it up on stands so I don't know if there is any shift problems as of yet.
