danlong
- October 16, 2003
- Gainesville, FL
- 2001 Sport Trac 2wd - V8
You seem to be correct. Here's the pin outs from the PCM connector:
Pin 58 (GY/BK) Vehicle Speed Sensor (VSS) +
Pin 68 (GY/BK) Vehicle Speed Sensor (VSS) +
Pin 84 (DG/WH) Turbine Shaft Speed sensor (TSS), Early production
Pin 84 (DB/YE) PCM - Output Shaft Speed Sensor (OSS), Late production
The member I mentioned who regeared and showed a change in the MPH-RPM correlation has a Job 1 truck (early model), so his speedo should be correct. I have a 2001 Job 2 truck, maybe I'll try pulling my RABS plug and see if my speedo still works just for kicks...
