The 2004 Sport Trac got a new electronic cluster with its own onboard microprocessor. Along with that change came a lot of rewiring. IMO, that alone makes the 2001~2003 ST a better candidate for an Ex 5.0 swap.
As mentioned above, a 99~2001 Explorer 5.0 would be the best choice for a ST because they are both mechanical returnless fuel.
However there are still some electrical issues that would need to be addressed, even for a 2001~2003 ST using a 99~2001 Ex 5.0.
Tachometer:
One wire pin needs to be relocated behind the cluster to make the tachometer read the V8 correctly. Easy.
Passive Anti-Theft System (SecuriLock):
98~2001 Explorers are type B PATS which uses a standalone PATS Module. All 2001~2003 STs manufactured after 7/24/00 have type E PATS which has the PATS Module functions integrated into the PCM. (If you can find a rare early 2001MY ST manufactured before that date, it should have the same B PATS as the 5.0L Ex.)
For the 2001.5~2003 Sport Tracs that came with type E PATS: if you just swap in the 98+ Explorer 5.0 and its PCM/calibration, PATS will no longer work and the engine will not start. To correct this, you have 2 choices:
- Find a way to bypass/disable PATS; or
- Install and wire the PATS Module and PATS transceiver from the 5.0 Ex into the ST. You would also need #1 transponder keys to match the type B PATS components.
Vehicle Speed Sensor:
In the case of 98+ 5.0 Explorers, the raw speedometer signal originates at the rear axle ABS sensor and is corrected and output as a square wave from the 4WABS Module. It is sent from there to the PCM, speedometer, speed control, etc. [Note: Early 2001MY ST (probably before 7/24/00) use the same system as the 98~2001 5.0 Explorer. That should make the speedometer work without further modification]
By contrast, the 2001.5 ~2003 Sport Trac takes the raw signal from the OSS sensor on the transmission and the PCM outputs the corrected square wave to be used by the speedometer, speed control, etc.
The 4WABS Module in the 2001.5~2003 Sport Trac cannot make the speed correction like the 4WABS Module in the 5.0 Explorer can. So, simply swapping the Ex PCM into the Sport Trac will leave the vehicle without a speedometer, odometer, speed control and anything else that requires the corrected square wave.
There are a couple of ways around this:
- Swap in the 4WABS Module and G-force sensor from the 5.0L Ex and rewire to support it. The problem with this method is that the 4WABS in the ST has Electronic Brake Force Distribution (front/rear proportioning done by comparing slip ratios in software) but the 5.0 Ex has a mechanical proportioning valve. Using the 5.0L Ex 4WABS Module in the Sport Trac would leave it with no front/rear brake proportioning whatsoever - not good.
- Use the Ex PCM and the original ST 4WABS Module and then add a dedicated module just for the speed conversion. Properly wired, a GEM from a 2001 2.5L Ranger will work for this.
