Not alot, but you will need to weld them on or have them welded on. Also you'll need longer shocks. For the front...you'll need to get drop brackets, coils, shocks, brake lines, extended radius arms (worth it), steering, and MISC.
Ok then since the soa gives you 6" and you want 4", you'll either need a custom leaf pack that that will lower it 2" or just leave them under the axle and get a 4" lift spring pack.
I only want to run 32s or 33s. i want the spring on top of the axle cause i am tired of getting my shock mounts and all other hard ware bent and broken. Do you know of any packs that are flatter than the stock one.
I suppose i could take out the over load but i would need a tracktion bar or something wouldnt i.
