Firstimeford
- August 1, 2011
- Little Elm, Texas
- '01 Sport Trac 4X4
I've been hearing a squealing noise for a while starting at about 40 mph on up. It sounds to me like it's coming from the left side but I can't tell if it's front or rear. At first I thought it was the brake pad wear indicator but when I inspected the brake pads they look new. I took it to an independent shop and they said it was the transfer case. This is on a 2001 ST with 73000 miles. When the shop put it on the lift, raised the rear end and ran it up to 45 mph you couldn't hear a squeal, but there was some noise coming from the transfer case. It didn't sound like anything abnormal to me, just "mechanical" sounds, but I don't know what it's "supposed" to sound like. After they told me it was the transfer case, I drove it to 50 mph so I could hear the squeal and shifted into 4WD. It made no difference in the sound whether I was in 2WD or 4WD. The noise doesn't change whether turning right, left or while touching the brakes. Does this sound like a transfer case problem to you guys? BTW, the transfer case looks new compared to the rest of the undercarriage.
