JamesInTahoe
- February 12, 2015
- South Lake Tahoe, CA
- 2005 Sport Trac XLT
Hi all,
Looking for thoughts on a problem I'm having with my 2005 Sport Trac 4WD. I've got about 240,000 miles on it. Recently, when I put it in 4WD HI I get a loud clunk pretty often (ever few to every 10 or 15 seconds) when I'm under power on a slick surface. It doesn't seem to happen if I run it in 4WD on pavement (yeah, I know you're not supposed to do this, but I wanted to see if it made a difference if I was in a situation where the wheels couldn't slip). Almost sounds and feels like I'm hitting a pot hole.
I replaced the front axles and the front driveshaft, so it's not a CV joint.
Seems like the only thing left is the transfer case and the front differential. I've read some comments that the chain can stretch in the transfer case so it can slip. But before I try and find a used transfer case, was wondering if (a) there are any other thoughts on what it might be, and (b) any thoughts on how to confirm it's the transfer case. Unfortunately, Sport Tracs have a different transfer case part no. (4L24-7A195-CA) from Explorers (all AB-AF part nos.) so it's a pain to even find a used one.
Thanks,
James
Thanks,
James
