Stalling when put in Drive | Ford Explorer Forums
wjg
Puerto Rico
'00 XLS
hi guys :)
im having this problem with my truck:
when i turn it on, and turn on the A/C, RPMs bounce up and down and it almost stalls. When i put it in Drive, it stalls and it would only move forward if i put it in 1. also, when i get it moving and put it back to Drive, the truck feels like the 4th gear engages (kinda like wanting to accelerate a manual car from a stop in 5th gear) and it shudders a LOT. i cleaned the MAF just now and the problem persists...
any ideas?? 00 XLS 4.0 SOHC
thx
Check for leaks on intake manifold and surrounding vacuum hoses.
had almost same probs turned out to be a cracked spark plug
where is the IAC located?...i recently cleaned the MAF and some kind of valve that goes on top of the intake manifold. BTW the truck has 120k miles and the spark plugs are the ones that came with the truck back in 00 lol...which spark plugs do you recommend?
On top of the intake manifold.
yes, i cleaned that on the weekend and it hasnt happened again. i also set the TPS to .96 :)
what about the spark plugs? which brand do you prefer?
