Hey all,
I was looking into solutions for corroded copper wiring causing resistance and ultimately loss of voltage. I am waiting on some electrical components to finish my wiring project and have about 400ft of 12g wire and 200ft of 16g of wire, the wire i have is standard over the shelf stuff, which will do fine for what im doing but...
Now i have stumbled on this silver coated wire, that has a higher heat tolorance, claims to allow voltage to flow easier because the silver each wire is coated in conducts electricity better than standard copper. Which helps with voltage drop. The wires are coated in thicker insulation that are better to deal with abrasion.
I have heard that these can and can't be used in areas that may be exposed to moisture, that they too are able to corrode and mess up.
My question is has anyone used these wires before and do you know anything about these wires. Any real benefits or negatives?
