AFradartech813
- October 25, 2014
- Goldsboro, NC
- 2005 Explorer XLT 4x4
As the title states, when i start the truck on a cold start, and only a cold start, i get a grinding/squealing noise that sounds like when you would try and start the truck when it is already running. This lasts for a second or two, and then goes away. After the truck warms up and i drive somewhere and start it again, it doesn't do it at all. Only when the truck is cold. When the weather is warmer, generally above 50 degrees, it doesn't happen at all. Has anyone experienced this? I can clarify some info if needed.
