I have the negative wire running from the battery to the starter motor bolt with the double thread & nut in the center of the bolt which screws into the transmission leaving the other thread end to mount the earth wire to, So that will be earthed well. I was leaning inside the wagon & heard the loud crack from where ever that noise came from, My wife was leaning over the left guard with the camera when it happened to take picture of the motor when it started, But jumped back when it made the noise, she said it sounded like an electrical noise but could't se where it come from, There was no smoke. I will have to keep looking & checking the wiring as I go. I removed the starter relay & it looked ok, I thought it may have blowen between the to points bent towards the center, but on further inspection the other relays are the same so I will keep looking
