- November 6, 2000
- 2018 EX Sport Concept
A few weeks ago my X had some intermittent stumbling on cold start in the morning, once every few days it would start, but immediately after the RPMs went up, instead of dropping to fast idle speed, they dropped to ~500 RPM and it would stall. Turn the key again and it starts fine, works fantastic the rest of the day. This gradually increased in frequency until it became a daily occurance.
Because the fuel pump was making noise that was audible inside the vehicle with the engine running, I've replaced the entire fuel pump assembly (NAPA) thinking it was the check valve or just a worn out old pump that was on its way out, and for two days or so after that, there were no problems. (Seemingly unrelated, the battery died during the fuel pump install, weird) Now the same stumble on cold start in the morning is back, but it doesn't stall out. The RPMs still drop, but pick up after 1-2 sec. and go right to fast idle speed. The new fuel pump is still quite audible from outside the vehicle (window down), but gets quiet when driving, even just getting rolling in 1st gear.
I'm looking for suggestions, at least hoping to reduce the cost of throwing a FPR, IAC, TPS, CPS, etc. at it until it's fixed. I'm considering replacing the Fuel Pressure Regulator, but theres no fuel in the vacuum line connected to it or the vacuum tree. However, I do have zilch for fuel pressure at the rail after it has sat overnight. The fuel pump does cycle on when the key is turned, but even turning it on and off a few times before starting doesn't seem to make any difference, the stumble still happens. This definitely seems fuel related since a new pump made a difference, going from a stumbling then stalling problem to just stumbling. There are no other problems, idle speed and performance are fine the rest of the time. I noticed in a few other threads some others are having this issue, so help us out! Thanks in advance.
