extra info. we didnt disconnect the steering shaft before lifting, the shaft was extended about 2 inches, Didnt think this was a problem because the steering has to extend when the axles drop right? well we put the extention that came with the kit in last and the steering shaft went back to its origional way. could there be a way I messed up shaft on the inside of the firewall that I'm not seeing? it also makes a click or small bang sound when I drive down dirt roads or over bumpy roads. the same sound that it made at first when I turned the wheel.
It started out as a click click click click kind of thing (maybe a few times per full rotation) as I turned now its still doing the click click click thing, but there is also a grinding sound and feel about it. if that makes any sence.
Just worried I screwed up the bearings or the shaft itself.
