Stock 1991-1994 forum welcome | Ford Explorer Forums
Status
Not open for further replies.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
Welcome to the Stock 1991-1994 Explorers Forum..
This forum is for GENERAL QUESTIONS about the first generation explorer...
Troubleshooting help posts should be placed in the Under The Hood Section or in the Transmission/Transfer Case forum depending on what your troubleshooting.
Questions on modifying your explorer should be posted in the Modified Explorer forum.
Examples of general question threads would be...
What is the correct torque spec for head bolts on a 1993 Explorer?
or
What is the gear ratio of the low range in the transfer case on my 1992 Explorer?
And as always, remember to use the search function, you will have an answer quicker if you find it in the search instead of waiting for someone to answer.
Welcome. I am here to assist Maniak in the 1st generation explorer section.
Copied from above!
There is alot of info on here already so don't be afraid to search first!
Status
