stock tcase w/ bw1350 | Ford Explorer Forums
fordmanSLO
Davis, CA
92 XLT 4x4
Wondering if its possible to 'add' in a tcase out of a 85 bII (i think bw1350) and double them up, without using someone's (expensive) doubling kit. I think the main issue I'm having is the technical details of it. If I just mate the 2nd tcase after the first, will I just have to index it so I can route the front driveshaft? Does anyone have some good options for this? Thanks
unless the second trasfer case is run off of a driveshaft and not a input/output shaft deal you can add whatever you want... it will however require a custom x-memember to mount the second t-case on and custon driveshafts front and rear and a custom shaft from the stock t-case to the second t-case.
