1992explorer
- August 18, 2005
- Lantana, FL
- 2002 XLT
This is the worse time for this to happen. No matter what setting my vent selector is on (MAX AC, AC, Upper fan, lower fan, window defrost...) the vent only blows air from the window defrost and the floor. It does not come out of the middle vents that blow right on you. It randomly worked about a month ago. I turned it to AC and air came out of the correct spot. It kept working until I accidentally switched it to defrost after 2 weeks. As long as I didn't move it, it worked.
So my question is what do I need to adjest to correct this problem. I am in FL and buring up!!!
Thanks for your help.
