Iron-Mike
- May 30, 2006
- Boston, MA
- '00 Limited
I have the following setup in my explorer:
Kenwood DDX6019 (In dash DVD touchscreen)
Kenwood KCA-BT100 (Bluetooth phone connection)
Kenwood LZH-70W (7" Overhead screen for rear passengers)
Kenwood KFC-ST30 (1" Dome Tweeters / 40w RMS & 120w Peak)
Kenwood KFC-1651S (6.5" Door speakers / 35w RMS & 160 Peak) 2 pair
Kenwood KAC-9102D (Mono amp / 500w RMS & 1700 Peak)
Kenwood KAC-8403 (4 channel amp / 60w RMS & 800 Peak)
Kenwood KFC-W3011 (12" Subs / 400w RMS & 1200 Peak) 1 pair
8ga power wire running from battery (with 100amp fuse) back to a distributor block with a pair of 100amp fuses.
8ga power wire running from the distributor block to each of the amps.
8ga ground wire from each amp to a bolt that secures the rear seats to the frame
the amps are mounted to the back of the plate that is on the back of the rear seats so they are hidden from view. There is ample space for the amps to breathe back there and they don't get bumped into or anything either.
ok now here is the story....
I have the 6.5" speakers and the tweeters running off the 4 channel amp and it runs perfectly fine and never cuts out on me.
I have the pair of subs running off the mono amp (not bridged) and for some reason the mono amp will cut out for like 2 minutes then come back if I am playing the system with the volume up a bit.
I pretty much have the gain set all the way up on the amp but have the bass at -18 on the deck which produces a respectable amount of bass without overextending the subs or the amp.
What am I doing wrong that is causing the mono amp to cut out periodically?
I am considering getting a capacitor for the system but my headlights don't dim with the system on cuz I have HIDs so they take a lower draw from the battery to begin with.
Mike
Mike
