mbed
- December 3, 2014
- 2002 Explorer
Greetings all!
Odd series of events. My 02 has 296k mi (second engine) and had trans rebuilt maybe 120-150k back. Son is back from college and didn't know how to turn off lights, thinking they were automatic. Battery fully drained, locked with keys inside. Called AAA to jimmy the lock using the blow up wedge and the long reach tool.
Until now, truck was running relatively well with only issue was no light showed up for 4WD High when starting and slight(?) EGR flow issue. MPG was tolerable and it seemed rust would be what would do the vehicle in.
So now, after using a jump box from AAA, got started, ran for a bit and decided to back out the driveway (slight downhill slope). Put in R and went out to street. Put in Drive and nothing! back to reverse, all low gears and no feeling whatsoever of any connection between trans and engine!
Also noted the 4WD Low light is now on and cannot shift out of it. Pushed it in neutral to curb and when putting in park, heard a major grinding / whirring sound that stopped within a few seconds.
Anyone know what could have happened?
Thanks in advance!!!
