Suggestions for rear air deflector | Ford Explorer Forums
MattStarr
Elite Explorer<br>ECX Member
St Petersburg, FL
99' EB Expedition
I am considering getting one of the EGR or LUND Rear Dustgaurds. I am wondering if anyone could post pics of theirs. I also would like to know once one is installed, can you still lift the rear tailgate all the way open? One more question, which is better to get... one that attaches with 3m tape and clips, or one that is drilled in? Where do these "clips" attach if I did get one with clips? I know there are alot of questions but if you know the answer to any one of the questions, please post all you know... ALL input is welcome... thanks alot .... M.S.
If you are buying it to move air over the rear window this type is best. Dead Link Removed
I have a weathertech deflector that works great.
I have had the EGR and while it looked good it did not move much air. Gotta think the Lund is similar.
Its real easy for me to tell in the winter when the vapor smoke from the dual exhaust is visialbe in the mirror.
If you get the kind you drill you are preety well locked in to keeping it cause of the holes. If your not sure, get the tape type. Not sure about the clips.
The hatch works as well with any of them. No problem.
I used the Lund Windjammer on my 99. It was painted to match the body color.
Take a look at the install threas at Dead Link Removed
Good luck.....
HEre is the one I have, it is a Turbo Shield from Explorer Express. It is installed with 3M tape and 3 screw per bracket(2 brackets) It cost $82.95.......
Dead Link Removed
I have the lund....doesn't do that great of a job clearing the back window. You can attach it with either or both methods. I only used the 3M tape....that thing will not come off. Even with the horrible weather up here, and driving 90MPH on the e-way...it won't come off.
