94Sport5
- April 5, 2018
- Points
- 18
- North Dakota
- 1994 Ford Explorer Sport
Hello..I'm just another longtime forum lurker that needs some help!! I have a 94 Explorer Sport 4x4 with the m5od. When I first got it, this problem had NEVER occurred..I remember because I have clocked acceleration times before when I first got it before ever doing anything to it or even having it worked on... (9.3 sec 0-60 w/ 3.27 gears btw! ) I could give it WOT in any gear and it would seem very happy and healthy, and would actually pull through the entire gear's power band..so I know I have something odd going on. Well anyways, after having weird coolant problems and later on blowing what happened to be an intake gasket, then having some work done to fix it (intake and valve cover gaskets replaced, and later had the transmission replaced due to internal lockup, and more work later on), only this one problem has come up and never went away. OK, If for instance I need to get on the throttle to pass somebody or in an event where heavy acceleration would need to be used, once the rpms climb to about 3700-4000, I literally lose all my power..the poor thing just falls flat and the engine will even begin to surge like it's trying to push harder but it's being held back. When this is happening there are some times where the rpms will get up to a certain point (3700-4000) then they just wont go higher at all, like I stopped accelerating and power is severely diminished, then other times when it gets up there it will begin to surge as its trying to push through like I said before. I think the clutch is good, it shifts great actually..2nd and 4th gears will grind if i try to shift quick but i can prevent it by timing the shifts right. (Junkyard transmission- bad synchros?)Things I have done to try and help it are: I replace spark plugs and wires (had high hopes this would work because of the symptoms and knew they both needed to be replaced badly anyway), replaced intake tube and box with ifab kit(definitely helped power and added some growl, but did not help the problem I'm having, nor made it worse), replaced the fuel filter, changed oil with full synthetic, and I also went through the koeo and koer diagnostics and it passed both tests...I understand I have some obvious stuff to check yet that I havent listed like checking condition of the coil, or monitoring the fuel pressure while the truck is having the problem..and that's what I'm leaning toward next, that it's possibly the fuel pump (I have run her out of gas a couple times). I have noticed last winter and in the beginning of the year that I was having to cycle the key as much as 3 times to fully prime the lines, but lately it has been doing it in just one cycle. On humid days though or like I said when winter comes around, it gets that way to where I will surely have to cycle the key multiple times to get it to start quickly and as it shoulf. Would that make the problem lead more toward the fuel pump? Or could it possibly be an injector issue? One other thing I'm unsure would have an effect..but I know for sure that when I replaced the thermostat I by accident put the weep hole portion pointing towards about 5 o'clock..I did it in -20 degree weather and definitely rushed it..it wasn't until a week after it was done I had read the weep hole should be up at 12 o'clock specifically. I plan to turn it back before the snow hits anyway so i possibly have a lil better heat, but yeah just so thats out there. I have thought maybe the computer isn't letting me have full throttle because the temp wont hardly ever even reach the n in normal, but it does get into the brackets..and I do get heat so the thermostat must work, but that idea just isn't fitting with the severity and consistency of the problem.. But hey sorry for the big post (I know there's plenty on here) and the rambling..and I apologize if this is in a wrong section as this is my first time posting. Any help will be greatly appreciated and I will be detailed about anything someone needs to know! I absolutely love this truck and I feel it can/will last me a helluva long time! Thanks!!
