nitro71
- April 30, 2009
- Spokane WA
From what I'm understanding going from a limited slip to open rear end requires swapping the carrier. I'm pretty sure the carrier is the whole internal differential part with gears and everything, ring and spiders?
When putting the new open carrier back in you'll have to set backlash. Backlash is the side to side position of of the carrier? You use shims and a guage to set that. Would a guage such as this be suitable:
http://www.amazon.com/Grizzly-G9849-Magnetic-Indicator-Combo/dp/B0000DD0VA
Found this kicking write up by some guy:
http://www.corral.net/tech/drivetrain/gears.html
