ROBinGa
- February 16, 2014
- Ga
- 2003 Explorer XLT 4x4 4.6
Hey guys I would like some feedback. I have a 2003 Explorer XLT with 4.6 and 4x4. The upper control arm ball joint on drivers side is cracked and making squeaks. Also the sway bar link is very loose on that side. The front brakes are grinding and rotors have grooves. This is wife's daily driver and I was told her car makes funny noise and found these problems when I went out to look at it. So it's been parked this week while I waited on parts to come and my son and I are going to tackle these things in the morning. So I ordered - new complete UCAs for both sides, new rotors and pads both front and rear, sway bar end links for both sides in front. Struts for all corners are coming but not here yet and I need to get brakes back on so she can drive Monday, so those will be done in a couple weekends from now.
Here is the order in which I plan to do this tomorrow:
1. Loosen front tire lug nuts on front enough to be able to get off once raised
2 Jack it up and put jack stands under front cross member
3. Follow steps on some posts here to replace Upper Control Arm on driver side
4. Replace sway bar end link
5. Raise suspension parts to ride level and torque the UCA and sway link nuts
6. Remove caliper, bracket, and old rotor then clean all surfaces, and grease caliper slides and contact points for pads with brake clips
7. Install new rotor
8. Replace bracket and caliper and new pads
9. Repeat this for passenger side. Put front tires back on and lower front end
10. Loosen rear lugs, jack the rear end and put jack stands under frame in front of rear wheels
11. Remove rear brake caliper and rotor, clean surfaces, then install rotor and rear pads, then repeat on other side
12. Bleed the brake fluid in lines starting at rear passenger side, move to rear driver side and bleed that one, then put tires back on , lower and torque rear lug nuts.
13. Raise front end again and bleed the front brake lines starting on passenger and ending with driver brake line. I plan to purge all the brake fluid following a YouTube video on ChrisFix site. I have 32 oz of brake fluid just bought today to purge it all while bleeding lines.
14. Then I will prep the brakes in my drive before testing them in my neighborhood streets. The pads I bought are ceramic and it advises to burnish the pads with 20 stops from 30 mph with 30 second between the stops process.
After all this I hope the Explorer will at least be back operable and safe brakes. When the struts come I will replace those then take for tire rotation and alignment. Does my plan for tomorrow seem the correct order and reasonable? Would love the feedback. Thanks!
