Blacksheep Josh
Slinky+Escalator=Fun
- July 31, 2006
- Statesboro, GA
- '01 Ford Ranger, RIP 93 X
Please read the posts. My amps and subs that I have are posted twice now..
'I am running 2500w rms off kicker zx2500.1 and my voltage never once goes into 12's. I got stinger volt meter in my explorer. I float at lower 14, high 13s at 45/50 volume. at full tilt my electrical stays at 13.3 to 13.5 depending which song it is you know.
The alternator MAKES the power. The battery STORES the power. A capacitor, stores a smaller amount of power than the battery, but releases that power MUCH faster than the battery. When your headlights blink, it's because the stereo has called for more power than the alt can deliver, and the system is falling back on the battery. The Cap is like a shock absorber. Just be sure that you get 1 farad of capacitance per 1000 watts of amp power. Also, do NOT get the batt caps, or larger 25-100 farad carbon caps. Your BEST bet is to get single 1 farad electrolytic caps, and bridge them together. They have lower internal resistace. If their internal resistance is not lower than your battery, you gain nothing. But, the nice thing is that when you run caps in parallel, their internal resistance goes down.
And you have zero headlight dim? Can you list everything you have? Like Alternator, Batteries, Caps?
Dude just buy a smaller battery rather than a capacitor IMO.
Buy one of the smaller Kinetik batteries, should do you good (that is what I want to add to my system later down the road)
Now, some guys have argued that a cap does nothing. Well, if you run the system from the battery alone, sure. You're not having a problem with the drop in current from the alt's operating voltage, to the battery's float voltage, on heavy bass notes. And, if your system doesn't even come close to taxing the alt, again, correct. But....for the majority of guys that only have one alt, and 2000-3000+ Watts, you could get close to the alts max operating output. And, when you have blinking headlights, only at or near full volume, you probably need a cap.
Sorry, this is not correct. A cap does not have to fully discharge, before it can charge again. A cap will discharge until the demand cycle is over. In other words, if the bass note overruns the charging system capacity for 1/4 of a second...that's how long the cap will discharge. Then it will charge back to the alt's float voltage. If the bass note is a full second, that's how long the cap will discharge, before charging back. Now, if you have a large bank of caps...let's just say 50 of them. That might be a ridiculous amount, but to make a point we'll just assume that many are in your vehicle. The bass note hits, and your charging system can't deliver. Your caps come in, at that point. They will discharge...as much as is needed, and then charge back. The caps will not drain below the voltage of the battery. They share the same charging path, after all. I stated this in my previous post, but apparently I'll have to say it again. You CANNOT have too much capacitance.my opinion on capacitors is to have just a little bit more than you need. what i have always been told is that a capacitor is either 100% full, charging, or discharging all the way down to empty. it cannot start to discharge and then charge again before it fully discharges. meaning if you have 10 times more capacitance you have to discharge 10 times as long and charge 10 times as long. i prefer to keep the charging/discharging cycles as short as possible. the purpose of the cap is to be quick. having the extra juice during the discharge is great and more would not be bad, but it would take longer to recharge.
Blacksheep, are you talking about power wire to the sub amps, or speaker wire to the subs? Because there should be no need for wire that size for the speaker wire to the subs. Larger power wire to the amps will only be useful if the amps can accept that wire guage.3. 2 Capacitors/Change wiring for subs from 4 gauge to a run of 1/0 gauge
I have an Odyysey 1750. It's a direct replacement for the factory battery size. No modifications to the battery location needed. And, it's an AGM style. This type can be deeply discharged without fear of battery damage.2. Better battery under hood (what would be a good one?)
HUH???!On Tuesday I'll probably work on the Big 3 upgrade. Where can I get a "one way wire" for the B+ to Battery cable? So juice can go from alternator to battery but not vice versa?
Wiring from the battery to the distribution block in the rear. My current setup is 4 gauge wiring from battery to distribution block in cargo bay, then from distribution block to amp are two 8 guage wires (EACH amp has 2 power inputs/outputs). I'm going to be using more power down the road, might as well upgrade now while I can.Blacksheep, are you talking about power wire to the sub amps, or speaker wire to the subs? Because there should be no need for wire that size for the speaker wire to the subs. Larger power wire to the amps will only be useful if the amps can accept that wire guage.
It's some kind of wire or fuse I've read about that let's energy through only in one direction. So let's say if my battery dies and I need a jumpstart, if I hook cables up to my battery the energy won't hit my alternator fully. Kinda like a "one way wire"... Idk, it's something I thought I read about, just another way to protect the alternator from seeing to much power.HUH???!
what kind of capacitor are you getting for 20 bucks
Ummmm, no. The only thing that can stop AC flow in one direction is a diode. As for DC, nothing flows in only one direction. I think you are barking up the wrong tree. Just use a 1/0 run of power wire for the ground, and power wire. You'll be fine.It's some kind of wire or fuse I've read about that let's energy through only in one direction. So let's say if my battery dies and I need a jumpstart, if I hook cables up to my battery the energy won't hit my alternator fully. Kinda like a "one way wire"... Idk, it's something I thought I read about, just another way to protect the alternator from seeing to much power.
