Test A4LD Vac Modulator | Ford Explorer Forums
stfree
Dallas, TX
1990 Ranger 4X4
Hello all,
I'm trying to determine what to expect in applying a vacuum to a suspect vacuum modulator on a A4LD '90 Ranger. Should I be able to pump a specific number of inches of vac and expect it to hold? What I see now is that I can rapidly pump down to about 10" of vac but it bleeds off within 3-4 seconds. I'm connected directly to the device straight off the pump with a known good hose.
Would this failure to hold vacuum create a problem shifting from 1-2?
So I evidently don't have this particular problem as the fluid levels are fine and I don't detect any fluid at the vacuum tree hose end and engine oil has normal color/level. So...I will check vacuum at the hose end at the vacuum tree and see if it holds vacuum there...If I did have a vacuum leak sufficient to cause shifting problems, wouldn't I also have problems with engine vacuum and rough running engine?
Thanks all!
