The new guy | Ford Explorer Forums
The new guy
fordpower
Whiterock
93 eXplorder
Hey guys ands girls. New to the site! Got a 94 eXploder that am going to lift four to five inches. Doing the axle over in the rear. Is that convertion kit from superlift ok? Looken for a cheap flip? That gives you five inches right? Want to also put some sound to it? Any exhaust tips? Great site... Thanks :fire:
the Superllift bracket spring over kit works okay yes, but you can also weld the spring perches on yourself and set the pinion angle for the increased lift.
Welcome and try searching, basically if you can dream it up for your Gen I Ex then it has been done, re-done, discussed, ripped out, rebuilt and done over again...
Exhaust
I want it loud ! Throaty! So I am going to have to raise the front a bit :confused: more with spacers to get at least 5" . I only got a 4" lift? Do you recommend a body lift? Was thinking 35's... eh This site rocks eh! Canadain Eh
Loud and throaty is a Flow Master 40 series and high flow cats.
If you don't want the stinck bug look then yes you'll need to lift the front some more. You could get the spacers. They will give you a little over an inch and fit 35s with some clearance trimming.
