chuckj5
- July 16, 2012
- Four Oaks, NC
- 1996 4.0 4x4 4dr Explorer
Hooked up OBC tester as soon as stuff was installed. That was when I saw the error codes.any issues with the wiring up to the coil pack? and did you clear the CEL?
replaced plug wires, numbered wires on both ends with marker before installing, so I'm sure of the order. Is there a procedure to check a coil pack while it is still in the box?Are you 120% sure you got all the wires on the right plugs and coil terminals?
