- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
Apparently you can adjust the tire size using Forscan to select predetermined sizes. This was mentioned some time ago by jmr061 I believe. That will allow the other OEM programmed modules, such as ABS, to get the correct info for their operation.Yes. The speedo may be a little off now (~1.5%=Speedo says 60 I am probably going 61) but as long as they fit and can handle the GVWR then all is good.
Mine are gloss black instead of the gunmetal gray. FYI, the gloss black ones have been disco'd. They scrounged to find me a set. Note that mine are the 46mm offset instead of these which are showing 0 for the offset. 45mm offset is the stock offset.
https://www.discounttire.com/buy-wheels/american-racing-vn215-classic-torq-thrust-ii-1-pc/p/56374
https://images.iconfigurators.com/i...achined-Lip_18850_5482_420_960_20.00_5482.png
