BigHarv19
- November 14, 2013
- Portland, OR
- 2002 Ford Explorer XLT
I am finishing up installing a rebuilt 4.0L Engine into my 02' X to replace the old one that seized. After taking a part the old one we found a bunch of broken plastic from what appeared to be the timing chain guide, and found that there was a bent valve/rod in 3rd cylinder which broke the piston. It was very similar to a thread (which I can no longer find) where the engine seized for what amounted to a timing chain tensioner wearing out and not holding the chain or the guide in place which lead to the bent valve/rod and ultimately the engine seizing.
So my question is now that I have new tensioners in place on the rebuilt engine, how many miles should I go before replacing the tensioners? Any suggestions for solutions would be greatly appreciated.
Thanks!
Also, any explanation would be awesome because I'm going through this for the first time and learning a ton from my father in law as I go, but certainly have a lot to learn.
Thanks!
