mcgyver ky
- March 25, 2003
- ky where all the mud is
- 91ford exporer eddiebauer
the main factor in storing oils and greases is exposure to temperature changeand moisture will reduce the shelf life
It is important to note that engine/motor oil, and transmission oil industry performance requirements are changing rapidly. The product may be stored three years and still be intact, but may not meet the latest specifications for your vehicle.
As a general rule, the simpler the oil formulation, the longer the shelf life. The following is a guideline under protected conditions:
Product Shelf Life
Base Oils, Process Oils Three(3) years
Hydraulic Oils, Compressor Oils, General Purpose Lubricating Oils Two(2) years
Engine Oils and Transmission Oils Three(3) years
Industrial and Automotive Gear Oils Two(2) years
Metal Working and Cutting Oils One(1) year
Greases Two(2) years
The following are signs of storage instability in a lubricant:
Settling out of the additives as a gel or sticky liquid
Floc or haze
Precipitates/solid material
Color change or haziness
Water contamination in a lubricant can be detected by a "milky" appearance of the product.
A sign of grease deterioration is the separation of the liquid oil from the solid grease.
Product Shelf Life
Floc or haze
