Tire Monitor / Sensor Fault
digifoss
Grants, NM
07 Explorer XLT
Just started getting this message recently. Got the "Tire Monitor Fault" coming home from a short trip a couple of weeks ago. It came on, stayed on for a few miles, then went out. Then last Thursday, driving down the highway, got the message again "Tire Monitor Fault", that stayed on a few miles, then it switch to "Tire Sensor Fault" then after about 5 miles, it cleared and hasn't come back on since. This is my first vehicle with tire monitors or sensors so I know nothing about that. Anything to check or suspect ? One thing, both times this happened it was snowing.
Rcflyer330
Michigan
2010 Ford Explorer XLT V6
Most likely its a sensor in one of the tires going bad. The battery life is 5 to 10 years anything past that is a bonus. Without the proper tools its hard to say exactly what sensor is the problem. If you have forscan and a bluetooth obd 2 scanner you may be able to find what sensor is the problem. The only problem is the position that the sensor was originally trained at will not match the actual position on the vehicle. For example forscan will report sensor 1 is the left front tire sensor, but that tire may have been rotated and is now at right rear position. The car can't tell the position of the sensor just that they are working correctly.
I just went through this on a 2012 Lincoln Navigator. I have a tpms tool that will trigger the sensors and read the data. With that tool, forscan and some work I was able find the bad sensor (it would not trigger) then program 4 new sensors with the original id's. I did end up re-training them to the vehicle because the shop said their tool would not read the sensors. I think they just wanted to sell 4 new sensors.
94Eddie
2010 Mountaineer Premier
This might not be your problem but it is worth checking out.
digifoss
Grants, NM
07 Explorer XLT
Thanks for the replies, sorry for the delay in getting back. Have not had the fault message happen any more. The video on how a phone charger can interfere with the sensor signal is pretty interesting and something I wouldn't have thought of. Knowing that, If it comes back on again Ill know if a charger is plugged in or not.
T Tire monitor fault Stock 2006 -2010 Explorers 1
G Tire Pressure Monitor Problem Stock 2006 -2010 Explorers 1
G help with Tire Monitor Fault Stock 2006 -2010 Explorers 3
F Tire size options? Stock 2006 -2010 Explorers 1
E Max Tire Size on 18" 2008 Explorer Limited. Stock 2006 -2010 Explorers 6
S 2006 Ford Explorer xlt tire sensor warning Stock 2006 -2010 Explorers 2
F Best Non-Snow Tire for Eddie Bauer 4X4? Stock 2006 -2010 Explorers 6
B Tire Fault Sensor Warning Light Stock 2006 -2010 Explorers 10
J Tire Sensor Woes Stock 2006 -2010 Explorers 6
T Felt Like I blew a Tire, But I didn't. Transmission? Stock 2006 -2010 Explorers 22
A Tire recommendation Stock 2006 -2010 Explorers 10
B Another tire size experiment - sorry! Stock 2006 -2010 Explorers 2
M Winter tire recommendation please Stock 2006 -2010 Explorers 14
D 2007 Esplora tire size help. Stock 2006 -2010 Explorers 2
B Rear tire chirp when going around corners, over uneven surfaces. Stock 2006 -2010 Explorers 2
Z Tire Sensor Fault Stock 2006 -2010 Explorers 4
D Tire swap Stock 2006 -2010 Explorers 7
P Tire Questions Stock 2006 -2010 Explorers 34
2 How do I know if I have the TIRE PRESSURE MONITORING SYSTEM (TPMS) Stock 2006 -2010 Explorers 4
Y Tire size that works with stock height and w/lift? Stock 2006 -2010 Explorers 6
S 265/70R17 Tire Will Fit Stock 2006 -2010 Explorers 2
B Stock wheel/tire downgrade advice Stock 2006 -2010 Explorers 7
D Tire size... Again Stock 2006 -2010 Explorers 1
1 Biggest A/T tire size on stock 17 inch rims for a 2006 Explorer? Stock 2006 -2010 Explorers 4
F Max Tire size on 2007 explorer? Stock 2006 -2010 Explorers 7
N Terrible Tire Shake Stock 2006 -2010 Explorers 11
J 2010 Explorer Tire Size vs Speed Stock 2006 -2010 Explorers 4
S Tire Upgrade Stock 2006 -2010 Explorers 0
B Tire Pressure Sensor Fault Stock 2006 -2010 Explorers 4
edwx Getting Tire Sensor Fault. What now? Stock 2006 -2010 Explorers 11
D DIY Procedure to Break Loose A Tire Bead Stock 2006 -2010 Explorers 4
G best tire for 235/65-18 Stock 2006 -2010 Explorers 6
M Tire size Stock 2006 -2010 Explorers 0
P Winter Tire Size?? Stock 2006 -2010 Explorers 4
C Inside Tire Wear on Both Rear Tires Stock 2006 -2010 Explorers 5
0 AWD rear tire movement Stock 2006 -2010 Explorers 3
M Tire Sensors Stock 2006 -2010 Explorers 5
F Tire sensor fault Stock 2006 -2010 Explorers 9
H 09 2wd front tire cupping Stock 2006 -2010 Explorers 2
P Tire replacement questions 08 LTD (18" Rims) Stock 2006 -2010 Explorers 4
C Tire Question Stock 2006 -2010 Explorers 5
C Bigger tire size. Stock 2006 -2010 Explorers 12
B Tire chains? Stock 2006 -2010 Explorers 2
S 235/65-18 to 255/60-18 Tire Upsize Stock 2006 -2010 Explorers 5
K 2007 Tire Pressure Light won't go out - Help Stock 2006 -2010 Explorers 7
N bf goodrich tire replacement help Stock 2006 -2010 Explorers 3
H Tire Sensor Fault Question Stock 2006 -2010 Explorers 8
D Knobby tire noise and clunk from front end related? Stock 2006 -2010 Explorers 3
B Tire size change Stock 2006 -2010 Explorers 3
R Change 1 Tire? Stock 2006 -2010 Explorers 16
Similar threads
