- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
This is advice only!! Your BEST option is to find another way to get those tires, borrow somebody else's vehicle, whatever. What I put below is a last resort of the damned:
Remove the front drive shaft and run any size tire you want. That saves the transfer case. Put a good used tire on the spare rim and use it to replace the bad leaking tire. Air your tires up, keep your speed low, avoid sharp maneuvers, and stop frequently to check the tires and let them cool down. Remember to set your parking brake when leaving the vehicle without a front driveshaft, it will drift even in park.
Ditto. The four current tires might not be the same diameter either, given the age and seemingly neglect of the tires(what are the chances they have been rotated properly).
If you remove the front drive shaft, then the tires can be mismatched and not hurt anything. If you can get four better tires for that trip, than the four best which match, spending the 30 minutes to yank the drive shaft would help.
What shape are the tires you have? It is possible to mix two pairs which together match each other. The AWD is actually comparing the total diameter of the two in front, to the two in back.
