Tires on stock 7 in. rims? | Ford Explorer Forums
Bushw@cker
Oregon
'97 XLT
Well, looking into some tires, most likely 31 x 10.5 since they are the biggest I can fit that won't rub (right?) without lift. Anyway, I saw that BFG says that the 31 x 10.5 can fit on 7 in. rims which i have stock. It would be great if i wouldn't have to buy new rims but would u guys put those tires on 7 in. rims? Doesn't sound like a good idea to me but if it will be ok just let me know.........
*EDIT* Oh yeah, forgot to say i am looking at the all terrains.....
they will fit on those rims fine... few have put 33x12.5's on 7 inch rims. did you try a search on the rubbing? some can fit 31's and some cant without rubbing.
you can safely put a tire up to 4" wider than the rim on.
7" rim= 11" tire, so you are fine.
fact is, i know many people who have run 32x11.5 and 33x12.5 on a 7" wide rim. the biggest i would do on there is 31x10.5, but thats me. in either case you are fine but dont count on the not rubbing issue. it probably wont, but nothing is 100%. if worse comes to worse, you can do a TT and some shackels for cheap.
the BFG all terrains are a fine tire, you will like them, i guarantee it.
So those should be ok on my stock 15x7s? Good. If they do rub I can always do TT and shackles like you said. Might be a problem if my paps doesn't want me to do that though. He was against me modding the truck in the first place but he has given in it seems. I can understand though since he did buy it for me to drive. Me paying part of insurance though. Getting off topic again :rolleyes:
try and have them test fitted before you buy. any shop or dealer should let you do that.
Good idea, I will try that. My friend told me that when he tried to buy 31s for his mazda pickup on the stock 7 in wheel, the tire store he got them from wouldn't let him do it. Weird huh?
if they dont let you tell them you will buy elsewhere then.
Lol, I bet they would change their mind then huh?
