radman
- December 27, 2006
- Location
- Indiana
- Camby
- 99 Eddie 5.0
My 99 Eddie 5.0 AWD has 90K on it now and I thought I would do it a favor and change the fluid in the transfer case. I removed the top plug (fill hole) first which is supposed to be the upper fill level and fluid came gushing out. I bought this car new and no one has touched the transfer case until today.
It appears to be over full. Can transmission fluid get into the the transfer case? Is there a seal at the rear shaft of the transmission to keep transmission fluid from getting into the transfer case?
About 8 years ago I had a shifting problem and found the transmission 1 quart low on fluid and no apparent leak. I did not think much about it but same thing happened about a year ago, fluid lose no leak.
What do you think?
Mike
What do you think?
Mike
